Cam position sensor and traction control lights, activate limp mode, help!
I have an 07 that just had some similar behavior. After changing the cam position sensor and seeing the same issue repeat, I took it to my local shop and they noticed my spark plug wires were toast. Replaced wires and plugs, and so far no codes.
I've noticed the problem only when the weather is warm or hot and the motor has run awhile.
I've replaced all the sensors and the issue still exists. My mechanic believes it may be an issue with the computer, which would be about $600 to replace. And that's no guarantee to fix it.
I'm going to have to try what was said about the plug and taping it up.
I have a 2007. I had the same issue. It only seemed to happen when the engine heated up. Was always fine when first starting out. Then check engine light, traction control light and limp mode. Tried some basic trouble shooting: changed the spark plugs,new cam sensor, new crank sensor, new battery, NOTHING worked. Finally found a rough looking EGR. Unplugged it and drove around for a day or so with no issues. Replace the EGR and have had no issues since. Since then I have put about 100 miles on the Jeep and so far so good. Hope this helps! I have also read that is could be an issue with the PCV. Good luck!
I just went through this with my 2014. Found some loose oil galley bolts in the motor (there was a service bulletin put out about it by Chrysler). From what we were told when those are loose (or fallen out like one of mine did) it changes the oil flow which can throw codes for the cam position sensors. I just got it back a week ago and so far no lights or anything. Just an idea of something different to look into.
