Can adding sway bar disconnects effect alignment
Old Nov 17, 2011 | 03:27 PM
Red Rock JK's Avatar
Default Can adding sway bar disconnects effect alignment
I just switched out the sway bar connections that came with my 3.5" lift kit. I add a set of JKS quicker disconnects. After I did, all of a sudden I have a slight pull to the left and a bad vibration at around 55 MPH? I didnt notice at first but it seems to be getting worse..
Old Nov 17, 2011 | 03:30 PM
nthinuf's Avatar
The JKS discos have a tendency to loosen up, but when tight, I haven't noticed any pull or vibes because of them. They just got kinda clunky because I neglected to follow the note about lock-tite in the instructions...
Old Nov 17, 2011 | 05:03 PM
Well I remembered the loctite, just cant figure out was else could have haapened?
