Can anyone answer this?
Old Apr 1, 2012 | 06:04 AM
JKCloak's Avatar
Default Can anyone answer this?
Be been looking at alot of 2.5" coil lifts and I noticed alot of people have good things to say about OME but none of the 2.5 kits for them come with any adjustable trac bar or adjustable LCA's. For it to ride well wouldn't you need the trac bar at a minimum and probably the LCA's also?
Old Apr 1, 2012 | 06:12 AM
tcdawg's Avatar
I think at 2.5" of lift you could probably "get away with it".
However, I would at least get an adjustable track bar or track bar bracket.
Old Apr 1, 2012 | 06:14 AM
Tonka_yellow's Avatar
The ome is more of a build your own kit. They would want you to get your own adj track bar. To be honest I probably won't go with a full kit. I might get things from different places to know they are the best part for the job
Old Apr 1, 2012 | 06:26 AM
Rule18's Avatar
My OME 2.5 heavy duty kit came with a trackbar.
Old Apr 1, 2012 | 06:47 AM
Atch's Avatar
I've been piecing my ome kit together, u don't NEED lca but I'll get them eventually to address the flighty feeling at interstate speeds
Old Apr 1, 2012 | 07:09 AM
TONKA TOY's Avatar
I have had my OME HD lift on now for about three months. The package came with JKS adjustable trac bar. I would wait and drive it for a while without the LCA's to see what u think. I don't plan on getting them. The "flighty" feeling is there but tolerable. I am very happy with the lift.
Old Apr 1, 2012 | 08:23 AM
JKCloak's Avatar
Ok guys thanks for the info!! I'm still debating on a lift but I'm trying to determine which parts a truly "necessary" and which ones arent
Old Apr 1, 2012 | 02:53 PM
Czep's Avatar
front adj trac bar is a must. front tends to wobble with 35s.
Old Apr 1, 2012 | 03:04 PM
jksooner's Avatar
I have not found this to be true on my 2012. I did get LCAs because I was flighty, but with the 35s, I have not noticed a wobble without the adj track bar
