Can I combine mopar sliders with mopar steps?
My Jeep came with the factory sliders, but I needed the 'nerf bars' or 'steps' so I took the sliders off and put on the steps. I was wondering if anyone here has tried combining the two together somehow to serve both purposes. Is there anyone that has already tried this? I would sure like to see some pictures and specs if you have! Thanks! HBC
no ... they use the same mounting location.
mopar sliders/steps
I agree,same mounting holes.
how about a stainless steel spacer and a longer bolt??
i was wondering the same thing for my rubi i want to use the sahara steps and keep the rails :thinking: |
I have the sahara steps , ruby rails are on the way (ups has them at the moment)
I assumed I'd swap them, but I'll look into a dual mount with washers and longer screws... I have my doubts but this is worth thinking about. |
x3, they both use the same mounting points. i thought about getting a set of steps and just swap them around whenever i go on the trails, but figured it be to much of a bother.
and i didnt bother trying to figer out if they could both go on because the way they sit, the steps are still able to be bashed against the rocks along with the sliders. You'd have to figure a way to mount them higher, or with something under them. there are several companies making rock sliders that double as steps. my favorite is the FatBoy 1000 Adjustable ones: http://www.4wd.com/aux_incl/images.a...pg&w=550&h=550 http://www.4wd.com/productdetails.as...=0&partID=8901 Side steps and rock sliders in one... the ReversaBars are also nice, but they can't be changed in position as easily as these can. I plan on getting these soon (birthday is coming up :D ) since my stock sliders are getting rather torn up. |
Originally Posted by oZmonKey
(Post 264412)
I assumed I'd swap them, but I'll look into a dual mount with washers and longer screws... I have my doubts but this is worth thinking about. Anyway, thanks for all the answers to my question. If someone else has another idea, let us know. HBC |
Originally Posted by atomicmecha
(Post 264421)
and i didnt bother trying to figer out if they could both go on because the way they sit, the steps are still able to be bashed against the rocks along with the sliders. You'd have to figure a way to mount them higher, or with something under them. there are several companies making rock sliders that double as steps. my favorite is the FatBoy 1000 Adjustable ones: http://www.4wd.com/aux_incl/images.a...pg&w=550&h=550 http://www.4wd.com/productdetails.as...=0&partID=8901 Side steps and rock sliders in one... the ReversaBars are also nice, but they can't be changed in position as easily as these can. I plan on getting these soon (birthday is coming up :D ) since my stock sliders are getting rather torn up. Cool idea. Thing is, I already have the sliders and the steps. If I can use them I'd rather not swap them for something else. By the way, Happy Birthday! HBC |
Originally Posted by naplesrubicon
(Post 264391)
sounds like a bad squaredance move. :thinking: |
