Can I fit 37's?
Old Jun 28, 2010 | 11:20 AM
08UnlimitedSahara810's Avatar
Default Can I fit 37's?
I am running the TF 2.5" BB right now, but will be going to 3" springs shortly. I have the Bushwacker flat Flares to be installed (they are sitting in my foyer at the moment, sorry honey). With this set up, can I fit 37's in there?
Thanks for the help!
Old Jun 28, 2010 | 11:22 AM
wayoflife's Avatar
JK-Forum Founder
in short - yes. i have done it but, you will need to trim your pinch seam if you haven't done so already.
Old Jun 28, 2010 | 12:03 PM
YingYang's Avatar
Yes you can... What WOL said and you are also going to need extended bump stops front and rear.
Im running a RockKrawler 3.5" mid arm with Bushwacker flats and I run 37's fine, just had to do the pinch seam and the extended bumps.
Im sure Planman will chime in, he has answered this questions a few times.
Old Jun 28, 2010 | 12:04 PM
redx08's Avatar
Yes you can, look at planman's write up on how to fit 37's with a 3 inch lift.
Old Jun 28, 2010 | 12:06 PM
Other than gearing, what did you to to your axles?
Old Jun 28, 2010 | 12:13 PM
redx08's Avatar
He is got chromo rear shafts, and he gussetes the c's. He is a hard core wheeler though. I think he even got a scratch the other day. jk with ya daniel
Old Jun 28, 2010 | 12:15 PM
YingYang's Avatar
Yo Mama Dont be hate'n cause my JK is prettier and has bigger boobies.
Old Jun 28, 2010 | 12:17 PM
YingYang's Avatar
What Redneck08 said plus I got a new front drive shaft. You can run your stock for a bit but it will eventually go south on you if you flex any.
Old Jun 28, 2010 | 12:19 PM
redx08's Avatar
x2 from redneck08
Old Jun 28, 2010 | 12:23 PM
redx08's Avatar
Implants are soon to come, but its ok my shafts are bigger in the front where it counts.
