can i should i
ok i have a 07 jk 4 door with front bumper&winch, i installed the teraflex 1" front coil spacer kit and that leveld it out. but now i want to install a 1.75"pro comp coil spacer kit and keep the 1" so i dont loose the level stance , i was going to put some RTV adheasive silicone between the spacers to help keep them from shifting will i have to make any adjustments to track bar to keep the stock alignment of the shaft and / or suspension
oh i also have bfg km2 33" on stock 17" rims w/ 1.5 wheel spacers and 1" m.o.r.e body lift
i hope that i made sence
thanks for your time and one more thing "I HAVE NO MORE MONEY"
I'm not the expert by any means but stacking 2 spacers doesn't sound like something I'd want to do. The silicon will not stop them from shifting if there is any lateral force applied! Personally I'd lose the 1" front spacer (and sell it to me..seriously) and get a kit with a larger front spacer than the back (Rubicon Express: 2 ½ front x 1 ¾ rear or Rough Country: 2 ½ front x 1 ½ rear). That would lift you and remove the rake.....safely.
lots of guys are stacking a 3/4" spacer on top of thier 2.5" spacers...
Just for clarity... the Rough country rear spacer is in fact a 2" spacer... unless they changed something.
