Can i still run Moab wheels?
Have 2013 JKU and I am going to put a 2.5" lift and I would like 35x12.50x17 tires, but I still want to run Moab wheels. Besides spacers will the tires even fit on factory rims?
no problem running that size on moabs...people run 37's on them. I had rubbing issue with my RK LCA since they don't have a bend in them but I added a washer each side and now they don't rub at all.
I'm doing just that as we speak. 1.5" spacers should get the job done nicely. I'd recommend a name brand (SpiderTrax, for example) so you know you are getting as high quality spacer - not some eBay knock off.
They are safe, and I think they are all Aluminum. The only "issue" is that they need to be torqued correctly and checked regularly. They will come with directions.
I am getting SpiderTrax, they have an excellent reputation and I have seen guys abuse them and they have had no issues.
See for more info:
https://www.jk-forum.com/forums/modi...r-help-220854/
I searched the forum and found no one mention a failure. They are very strong - probably stronger than the wheel is.
More info with technical analysis:
https://www.jk-forum.com/forums/modi...safety-130315/
See for more info:
