Can I use washers as temp wheel spacers solution?
Guys, I am doing my 2.5" TF lift kit now. However, I am getting my new wheels and tires package in few days. Question, can I get away with using two thick washers per wheel stud as a temporary (for few days) solution to substitute wheel spacers?
If u have stock wheels and tires and run the brake line brackets and sway bar links on the correct side with the bolts going the right way you dont need spacers to drive. Only when going bigger tires do u need the spacers. I ran my stock wheels and tires for three months, on and off road with the TF 2.5 lift with no problems.
Don't skimp... Is $150. Bucks worth you or your passengers lives... If that wheel came off at high way speed....yikes.
Put a WTB post in the classifieds... You will find a set of spider trax spacer in no time. I got mine second hand off the forum. Good luck.
That is exactly what I was hoping for, to get away without spacers for the few days with stock wheels and tires until I get new wheels/tires package. However, I installed TF in the rear last night and as soon as I took it out of the garage I noticed metal on metal rubbing sound. It was too late to investigate what is rubbing, but I will be doing it in the next 15 min.
