Can you help?
Old Dec 13, 2010 | 07:56 AM
JEEPS R US's Avatar
Default Can you help?
I just put a lift and tires on my 2010 jk once i got my alignment done all my warning lights turned off......but my tire warning light still indicates that the tire is low.....do u know how to fix it?........thanks
Old Dec 13, 2010 | 08:02 AM
wayoflife's Avatar
JK-Forum Founder
when you got the tires installed, did you install them on new wheels? if so, did you make sure to have tpms sensor installed? if not, that is your problem and i would recommend that you get an aev procal as it will allow you to turn off the warning light.
Old Dec 13, 2010 | 08:03 AM
SWAMP RAT's Avatar
Check the air pressure in all 4 tires as well as the spare. My TPMS light comes on when the psi drops below 30. Others have posted that their light comes on at different psi's.
