cant get door hinges to line back
Old Aug 31, 2010 | 07:32 PM
Scootersjk's Avatar
Default cant get door hinges to line back
I bed lined the door hinges and now i can not get them to line back up. all hinges went back to the exact location they came off of. It seems to be the bottom hinge on both sides. I tried loosining the hinges and shifting the door around but i couldnt even get the pin to drop all the way? wtf someone have any thought need help.
Old Aug 31, 2010 | 07:39 PM
Croce's Avatar
Not sure if it matters as i haven't remove the hinges yet, but could you of possibly swapped the hinges from the passenger side/Drivers side to the other side by accident?
Old Aug 31, 2010 | 07:52 PM
Scootersjk's Avatar
there is no paint under the hinge so when u put them back on they line up to that. I actually think it would be impossible to mix them up?
Old Aug 31, 2010 | 07:54 PM
mkjeep's Avatar
add some lube......also, play with the angle you drop it in and the swing back and forth.
Old Aug 31, 2010 | 07:59 PM
serveapurpose's Avatar
Sponsoring Vendor
Off Road Evolution Rep
Driver side and passenger sides are completely different since the pin is supposed to be on the bottom. Mine took awhile to get set right. Not sure if the top hinge is different than the bottom as far as where the hinge pin sits. good luck!
Old Aug 31, 2010 | 08:03 PM
Scootersjk's Avatar
i have been trying to do this with my 120lb wife, will try tommorow with my brother . i will try some lube also. i do not want to loosen the friggn torx on the door anymore. they are very soft and starting to strip
Old Aug 31, 2010 | 08:08 PM
Croce's Avatar
Im an idiot. Thought you meant the hinges that are attached to the jeep, not the doors.
