View Poll Results: Which differential fluid?
Synthetic 80W-90 Gear Lube
52.94%
Severe Gear 75W-90
11.76%
75W-90 Long Life Synthetic Gear Lube
29.41%
Severe Gear 75W-110
5.88%
Voters: 34. You may not vote on this poll
Cant make up my mind of differential fluids! Help!
Old Nov 6, 2010 | 02:48 AM
lakeguy's Avatar
There is no mention of different weights for front and back. Can I just go with the same weight front and back? I dont do much off roading and pretty much just use 4wd in the snow..
Old Nov 6, 2010 | 03:27 AM
Biggy's Avatar
Go with the severe gear 75-90. Thats what I use with no problems.
Old Nov 6, 2010 | 10:08 AM
nthinuf's Avatar
Open your Owners Manual...
SAE 80W-90 (or equivalent) in both axles
If you tow a lot, use
SAE 75W-140 (or equivalent) in the rear axle
Old Nov 6, 2010 | 12:04 PM
nbro's Avatar
Thumbs up
i know it wasnt an option but id go with royal purple
Old Nov 6, 2010 | 04:39 PM
ifshinxs's Avatar
Take some pressure off yourself....This is really easy..
For your needs ANY 75w-90 synthetic oil will do the job for you..if you want to spend a few more dollars to make yourself feel better knock yourself out.
I'm offroad alot and I tow my ATV trailer loaded with quads..Right now I use the Amsoil Severe gear 75w-90 up front and the 75w-140 in the rear. Only because I got a good deal on the Amsoil. Other wise it would have been Mobil 1.
In my last few Diesel trucks I ran Mobil 1 without issue and that was pulling large heavy trailers..
Old Nov 6, 2010 | 04:44 PM
CerOf's Avatar
Royal purple 75/140 front and rear here
Why? Cause I bought a lot about 5 years ago at $6/quart. Have about 4qts left.
Never had a diff problem with it.
