Can't remove nuts holding on wheel spacer
Old Dec 18, 2013 | 07:11 PM
joentuff's Avatar
Default Can't remove nuts holding on wheel spacer
Ok this seems crazy but I am have a terrible time removing the nuts holding the wheel spacers on, I've got a few off but still have 2 that seem impossible to loosen, I've used a impact but having no luck, any ideas?
Old Dec 18, 2013 | 07:21 PM
karls's Avatar
Break out the breaker bar. If that doesn't work then throw a cheater pipe on the end of it.
Sent from my DROID4 using Tapatalk
Old Dec 18, 2013 | 07:27 PM
5150cliff's Avatar
I'll bet that they were put on with Loctite and will need to be heated with a propane torch for a few seconds to melt the Loctite. Then they should come off relatively easy. Try it.
Old Dec 18, 2013 | 07:33 PM
BRUT4CE's Avatar
Former Member
This.......
