Car jack question.
Old Jan 16, 2013 | 05:00 PM
tkkim's Avatar
Default Car jack question.
My jku was lifted 2.5 in with 34' tire..
So i just wonder normal car jack can lift enough to do some job..
Old Jan 16, 2013 | 05:04 PM
hooper's Avatar
You can use it to change tires still. I would a floor jack for other times when im really working on it, especially if I need two tires off the ground at the same time.
Old Jan 16, 2013 | 05:18 PM
BoneShkr's Avatar
The "Foot" on the car jack needs to be modified into a cup.
Or to at least have an adapter to add to the square foot,
and attaching a cup to the foot.
The reason for this is simple. The Wrangler is a Solid Axle vehicle.
If You want to get both wheels off the ground, raise it from the
lowest point.... The Differential Housing.
If you do decide to do this, Please,please, please, Chock the
other Axles Wheels from moving in either direction.
Old Jan 16, 2013 | 05:19 PM
BlackRockBurner's Avatar
AEV makes a jack base thats designed to work with the scissor jack. It fits in the under floor storage bin, and doubles as a chock. I'm sure Sponsor Northridge carries it.
Old Jan 16, 2013 | 05:26 PM
conifers4's Avatar
I think he's asking if the jack will raise the truck high enough. If that is the case then my answer would be to put the factory jack on some 4x4's to compensate for the the lift. Works for me, just practice safety and chock the wheels as already stated.
Old Jan 16, 2013 | 05:28 PM
BoneShkr's Avatar
Thanks.
Here's a Link; northridge4x4.-accessories/trail-repair
Last edited by BoneShkr; Jan 18, 2013 at 05:47 PM. Reason: Updated Northridge4x4 Link
Old Jan 16, 2013 | 05:29 PM
k0260's Avatar
yeah I use one of the AEV bases, it works real good and stows away neatly. So nice to have with a lifted rig.
Old Jan 16, 2013 | 05:30 PM
tkkim's Avatar
Chock mean mark tire and ground that it was originally placed?
To protect axel?
Old Jan 16, 2013 | 05:35 PM
The AEV base goes on the ground, place the jack on top, and crank away. Gives you 3.5 inches extension and prevents that wobble.
Old Jan 16, 2013 | 05:38 PM
zstairlessone's Avatar
To protect axel?
Block a tire on the ground so it doesn't roll
