Caster??????
Old Aug 26, 2009 | 05:56 PM
JERSEYJK's Avatar
Originally Posted by fab1
What was the length eye to eye when you put them in if you look at WOL wright up it said to put them at 18 1/2 stock is 18 3/4. I have the same set up as you just put it in last sat and set my UCA at 18 1/2 and its driving good I am tacking it to a alignment shop tomorrow to cheek the caster and make sure my axles are centered. After their done I get under their and measure as close as I can to give you a stating point so you can figure it out from their.
I followed WOL's write up and measured 18 1/2" from center to center. Then itook it to the alignment shop and I don't know if they changed it but my printout stated 4.1.....but i did tell them that I wanted my caster at +6 to +8 but they said my caster was good and that I only had 3-4 threads left on the UCA's
Old Aug 26, 2009 | 07:22 PM
feroxjb's Avatar
The cambolts that I got with my RC lift are pretty much crap. I wouldn't waste my time using them (AND cutting out the metal tabs to install them). I could never get them completely equal, and they tended to shift.
I eventually just got a set of adju front uppers and it solved my flighty steering problem.
Old Aug 26, 2009 | 07:40 PM
nthinuf's Avatar
Again, that +6 to +8 is from an angle finder placed under the C's. It is NOT from a professional alignment machine. You can't compare the two sets of numbers. If you want to make sure you're in that range, grab an angle finder and go measure it yourself.
But regardless of what your caster is currently set at, I haven't seen you mention how it actually drives? Flighty? Bump steer? Or does it handle similar to stock? If the handling is good, don't worry about the +6 to +8...
Old Aug 26, 2009 | 08:17 PM
JERSEYJK's Avatar
Actually drives pretty good..drives straight...but I do feel some bumpsteer... Not much though.
