caster problem
Old Oct 13, 2010 | 06:37 AM
rhino4bs@yahoo.com's Avatar
Default caster problem
my jeep drives bad has 3 degrees of caster will adjustable arms help
Old Oct 13, 2010 | 08:01 AM
Dynatrac's Avatar
Sponsoring Manufacturer
Yes, but you may end up with drive line vibrations when you rotate the pinion.
Old Oct 13, 2010 | 08:09 AM
KenB1010's Avatar
I bet that it drives bad at 3 degrees. Stock is +4.2 and many are running at +6 degrees more positive camber than stock will get you better drivabily but at the cost of some driveline problems
