Caster Problem and Correction Help
Old May 21, 2010 | 03:48 AM
Dang It Dan's Avatar
Default Caster Problem and Correction Help
Hello everyone,
I read the stickys and did some searching but really can't find the answer I am looking for.
Here is the deal: I installed a Rough Country 3.25 lift with 35's. Since then, at anything over 45 mph, the jeep kinds wants to jump from left to right. Nothing extreme, but annoying. I learned this was a condition due to not enough caster angle.
Now, my lift did not come with adjustable lower control arms. Is there a good way to fix this without buying lower CA's, and what would be the procedure if I did buy them and install them myself (since no one around here in Florida seems to know what I am talking about).
Thanks.
Old May 21, 2010 | 04:03 AM
Robar's Avatar
There is not good way to fix caster with out using control arms. Cam bolts can be used but it is not a good substitute for control arms, as they can come loose and are ofter a source of constant maintenance.
As far as installing control arms it's not very difficult with a jack, a couple jack stands, a torque wrench and some hand tools. Just follow one of the lift kit write ups and jump to the control arm section.
Old May 21, 2010 | 01:23 PM
I was really hoping that there was something else I could do. The only adjustable control arms I found so far are about $425.00 each (ouch).
I am still wondering how and why I need to do this with only a 3.25" lift. So far, Rough Country has been less than helpful.
Old May 21, 2010 | 01:28 PM
JK-Tex's Avatar
Originally Posted by Dang It Dan
I was really hoping that there was something else I could do. The only adjustable control arms I found so far are about $425.00 each (ouch)..
I think you're reading that wrong. For instance, a set of TF arms from Northridge is $330 shipped (for both). I'm not aware of any arms that cost $850/pair.
http://northridge4x4.com/proddetail.php?prod=TF-1653700
Old May 21, 2010 | 01:39 PM
racer83l's Avatar
There are a few options for you... First, there are countless threads on this subject already.
Control arms are a great way to fix this. Currie, Rock Krawler, Teraflex, JKS are all good brands. Cam bolts are a cheap fix. People hate them, I ran them for a while with no issue. Currently I'm running control arm brackets from AEV that correct castor. There cheap ($99) and get the job done (they give up ~2" ground clearance at the bracket which for me isn't the issue considering how nice the jk rides now.
I also ran Currie control arms, liked them but the Johnny joints made the ride a bit harsh for me.. If I were to go back to control arms, it would be jks for their rubber bushings
Old May 21, 2010 | 05:42 PM
Thanks All,
I have some research to do here so I will check out some of the different brands. Just want to fix this and move on to actually driving the JK, and not working on it.
Old May 22, 2010 | 03:44 PM
nthinuf's Avatar
And remember that you only need 'one' set of arms to set your caster.
-Front Uppers are less expensive, but a bit harder to install, since you have to cut off a bolt.
-Front Lowers are a bit more expensive, but have a better range of adjustability.
(-Rear uppers will be used if you feel the need to replace your rear driveshaft.)
