Caster vs Pinion Angle
Old Dec 10, 2010 | 12:13 PM
JK_Tim's Avatar
Default Caster vs Pinion Angle
So Ill be getting a full set of adj. uppers and lowers for the front and rear to run aftermarket shafts. However I fail to see how to adjust the caster on the front end without negatively affecting the pinion angle. (4in lift). From what I understand so far, Shortening the front uppers = more caster, but wont that aim the pinion down more? I need it to aim up to be in line with the driveshaft, correct?
Old Dec 10, 2010 | 12:22 PM
nthinuf's Avatar
You are correct. Raise the caster until you get driveline vibes, then start lowering until you find the 'sweet spot' between flighty handling and vibes. (personally, I would take the caster down another notch past that point just in case...)
Other options are the new PR housing with built in caster/pinion correction. Or you can cut and turn your current housing. Or send it to a company that will do it for you.
Spend a few minutes out on Tom Woods website for more info and pics on this.
