cats
Old May 19, 2011 | 12:03 PM
Michael's Avatar
Default cats
Has anyone takin the catalytic converters out of an 08 wrangler yet? I was curious as to if they had trouble out of the ECM after they done it.
Old May 19, 2011 | 01:19 PM
jesse0376's Avatar
I dont know why anyone would want to.
Old May 19, 2011 | 01:34 PM
Jknockers's Avatar
If you or they do ya might have to run a resister to fool the ECM that the CAT is still installed,,, Maybe,,, look into it,,, I know thinkgs like this was done on some race cars out there that people had removed the CAT
Old May 20, 2011 | 01:23 PM
Michael's Avatar
I was just curious. I know on the older model vehicles they robbed a lot of power so we just took them out.
Old May 20, 2011 | 01:29 PM
T&ERun's Avatar
Can't do that anymore. You'll throw codes and won't pass inspection. It's also illegal so don't get caught. The cats these days aren't really that restrictive. You would gain maybe 5hp.
Old May 20, 2011 | 03:55 PM
Michael's Avatar
They don't check emmisions where I live. I was affraid of the codes thou. Thanks
Old May 20, 2011 | 03:58 PM
Jknockers's Avatar
Thats why I was sayin ya might have to put a resistor there to simulate the cat being there. I do remember reading that this was done on other vehicles before to "trick" the ECM that a "CAT" was still installed.
Old May 20, 2011 | 04:05 PM
Michael's Avatar
I'll try to do some research and see what I can find.
Old May 20, 2011 | 04:22 PM
myz28u's Avatar
Removing the cats would help with exhaust flow. O removed the cats from my 00 z28 when I installed headers and 3" exhaust. I had hp tuners siftware and simple turned off the codes to the computer. Not sure if superchips can do that with a hand held. If you are set on removing them and have to pass a sniff test, a dyno tuner could in theory create a volumetric efficiency mapping table to run your engine with the least amount of emissions just to pass the test. But all that is a big if. If and only if they have tunning software avail as ble for ours jeeps. So my opinion is just leave your cats alone.
