caution with air intake
Old May 11, 2012 | 04:17 PM
Murder¹'s Avatar
Default caution with air intake
So I just found out if you add a high flow air intake to your jeep you need to upgrade your radiator cap too. I was running low in coolant & we figured out the 18psi cap blows off the coolant so if you get an intake get a cap.
Old May 11, 2012 | 05:12 PM
OscarTheJeep's Avatar
Huh?
What does an air intake have to do with the radiator cap?
Old May 11, 2012 | 05:15 PM
Rule18's Avatar
I've had an Airaid for a year and a half and never had an issue. Not sure what the connection is.
Old May 11, 2012 | 05:20 PM
Murder¹'s Avatar
I dunno his friend has a titan that they had stuff done too & the pressure built up & was making the cap pop open & blow off steam. Thats all we could figure happened with mine I had barely any coolant & no leaks & my girls car has a cai
& has the same problem with keeping coolant so maybe it's not the solution but I can't find any other problem
Old May 11, 2012 | 05:23 PM
Rule18's Avatar
Weird. There wouldn't really be additional pressure buildup in the radiator as a result of an air intake. Post if any additional info comes out.
Old May 11, 2012 | 05:35 PM
Murder¹'s Avatar
Id never heard of it either but made sense maybe my cap was stuck in the popped position. Guess ill just keep some coolant close by & keep watching out
Old May 11, 2012 | 05:38 PM
TXCheney's Avatar
Sounds like a blown head gasket. Had the problem on my Titan before the jeep. What does the exhaust look like in the AM when you first start it? Nice part is it was warranty work.
Old May 11, 2012 | 05:55 PM
Murder¹'s Avatar
Exhaust looks normal
Old May 11, 2012 | 06:13 PM
saravonshep's Avatar
Check your oil, if their is a blown head gasket their will be water in your oil.
Old May 11, 2012 | 06:17 PM
Murder¹'s Avatar
Checked oil its good no problems that I can see there
