Center console removal help
Old Jan 5, 2009 | 07:04 PM
Sandtoy's Avatar
Default Center console removal help
Can't serem to get the center console around the shifter to come out.
anyone remove this? If so could you please provide some help?
Need to have out tomorrow.
thanks
Old Jan 5, 2009 | 07:35 PM
seer1's Avatar
Here are some pretty good instructions:
ht tp://www.atlas-tc.com/install/jk1.html
Old Jan 5, 2009 | 07:39 PM
seer1's Avatar
BTW, that lower center console panel has to be out and you REALLY have to yank the e-brake handle up. I mean really get it up high and watch out because if you accidentally hit the button that thing'll slam down real hard.
Old Jan 6, 2009 | 02:57 AM
Sandtoy's Avatar
Default Thank You
Thanks, I Followed your link and it worked perfectly. I did not have the E brake pulled far enough up.
Yanked it up and the console came right out.
Old Jan 6, 2009 | 04:11 AM
seer1's Avatar
Glad it worked for you. Man, are you up early or is it just me?
Old Jan 6, 2009 | 04:21 AM
dsy's Avatar
dsy
My ebrake must be adjusted tighter than normal. I could not raise the handle enough until I disconnected the cables at the rear wheels. Then the lever stands almost straight up. Its pretty easy to disc the cables at the wheels.
