Centerforce Clutch Rattle?
So I recently got my tranny partially rebuilt to fix the 6 Speed JOG issue (TSB should've been a recall) and had the Throwout bearing and clutch replaced at the same time. I went with CenterForce for both.
I love the feel of the clutch, a big improvement over stock. Also, for the first time since bought the Jeep just outside warranty I don't have to strong arm it to keep it in first gear.
Here's my issue, I noticed a faint rattle type noise when the clutch is out and the Jeep is idling. The noise goes away when the clutch is engaged and when traveling down the road. I took it back to the mechanic who said he thinks it is simply the design of the CenterForce and its normal.
He did offer to tear into and make sure but I told him I'd keep an ear on it for a few weeks and report back.
Those who CenterForce clutches with CF TOB's also do you have any noise? Do you agree that some noise is normal?
Thank you in advance!
RT
RT
Never on a Jeep, but I've installed many on Mustangs and it was always a toss up on whether they'd make noise or not. I'm personally not a fan of the Centerforce stuff but many like it and I used to give those that wanted them installed a heads up that it may or may not make noise.
There's a wire ring that runs through a series of weights that interlace the pp fingers so plenty of opportunity to make some noise especially at idle.
Another quick question, hypothetically speaking
if you really get on a new clutch during "break-in" could it slip a little and if it did is that something to worry about? Thank you all!
RT
Mine is doing the same thing. No Centerforce clutch for me though. Noise stops as soon as foot touches the pedal.
I have a bit left before warranty runs out and planned on taking it to dealer to have it checked out.
"Chirping" or "squeaking"? Throw out bearing, and fairly common too. In many cases it will eventually just go away. Sometimes not.
This is exactly what my mechanic was saying, thank you all for confirming what he was saying.
Thank you all!
RT
RT
If your shop performed the task correctly (new pilot bushing/bearing, TO bearing, PP/disc and turned the flywheel) then you'll be in good shape but it doesn't hurt to take it easy at first anyway.
mine from the factory has done this for 25,000 miles I call it sloppy workmanship the tollerences are not tight when building but meet specs so Chrysler and other manufactures allow them to leave the factory and we get stuck with them . And most people don't . Its not right in my opinion
, but I guess that's the way it goes . youl never get rid of it unless you prob buy a new tranny
http://www.nexternal.com/uuc/articles/gear_rattle.htm
id love the issue to be resolved but . ive had to deal with it too
, but I guess that's the way it goes . youl never get rid of it unless you prob buy a new trannyhttp://www.nexternal.com/uuc/articles/gear_rattle.htm
