centering steering wheel
Old Apr 16, 2008 | 10:19 AM
derekls's Avatar
Default centering steering wheel
Ok so its super easy to center the steering wheel, got that done,
but since i rotated the turn buckle, the bolts, they are now rotated to where they are almost touching my rubi skid, is this going to be a problem while going offroad?
As in when I flex will the bolts scrap or possibly bind my skid and cause some bad problems, OR does that bar stay stationary
thanks
derek
Old Apr 16, 2008 | 10:28 AM
derekls's Avatar
unless it helps any here is a pic of how I think it should be?
http://project-jk.com/wp-gallery2.php?g2_itemId=21620
when i got mine centered the bolts where pointed up toward the skid, and has very very little clearance, so if it does flex def will hit?
Old Apr 16, 2008 | 01:00 PM
bobzinger's Avatar
If you loosen the bolts enough, you should be able to move the bolts wherever you'd like... at least i was able to do so with mine...
Old Apr 16, 2008 | 01:04 PM
greenmachine07's Avatar
form my opnion nothing bad has happened to me so far
so idk if that helps any but yea
