Changing Gears - Computer Update Necessary?
I just changed gears from 3.21s to 5.13s. I put 35"s on the JK a month ago, and had the dealershp reset the computer after installing the 35s.
Does anyone know if the dealership needs to update the JK computer again after changing gears? also, any idea what all is updated?
Thanks.
Rick
Thanks.
Rick
I would say yes since your tires are now turning faster I'm sure your spedo is off again.
The dealer can reset (program) a jeep for larger tires? I thought you needed an aftermarket programmer for this....asking a question because I don't know.
Thanks.
Rick
Thanks.
Rick
The dealers can only re-flash your computer for the largest factory tire size. That would be a 32" tire. The re-gear will not effect your spedo, because the speed sensor is on the axle. The speed difference would only be between the 32" vs. 35" tire. This means your spedo will read 9.4% low. IOW, if your spedo reads 70MPH, then you will be really going 76.5MPH.
So, you in love with those 5.13 gears? I would be, because that will be one of my first mods when she gets here.
That would mean the speed sensor is more than just in the axle, correct? It'd be affected by both the gears and the tire size... I would think... otherwise, you'd be more than 2mph off... anyone else w/experience... I should have some input sometime after this week... my gears (5.13's) are getting installed this week with my lift and 35's.
I had 35's on mine with the stock 4.10's, and 35's when I installed my 5.13's. The speedo readings are the same with the 5.13's as they were with the 4.10's. My speedo reads about 9.3-9.4% slow.
That is weird that reads slow. I would think that it would read faster? Mine reads 3-6mph slow (depending on speed) as compared to the gps. I have 4:10's, 6sp, and 35's and want to go to 4:88's. I think the spedo is off from the start.
its maybe off by 2mph max, not enough to worry about
