Check Engine Light with CAI
Old Jun 9, 2007 | 07:11 PM
MikeReo's Avatar
Default Check Engine Light with CAI
I installed an aef cold air intake today and my check engine light is on. I was careful not to damage the sensor. The install went real smooth except for the indicator light. Anybody had this problem?
Thanks in advance
Old Jun 9, 2007 | 07:18 PM
JKJoe's Avatar
Try disconnecting the positive battery cable, and ground it to the neg side for around 30 seconds. Hook it back up, and see if it clears.
Old Jun 9, 2007 | 07:20 PM
MikeReo's Avatar
Thanx..I'll try that in the morning.
Robar's Avatar
I would double check the sensor connection and make sure there is no damage to the sensor if resetting the computer does not work.
Old Jun 9, 2007 | 07:26 PM
MikeReo's Avatar
It was tough to pull that sensor out without completelt smashing it. Whats the white putty looking crap on that sensor?
Old Jun 9, 2007 | 08:51 PM
BLKRUBI's Avatar
OH NO! You killed it!
