Checking components at full droop.
If I lift my front end up and set the frame on jack stands and the axle is resting under its own weight would this be my limit on droop or would I need to flex 1 side to let the the other side droop further to find what is limiting my down travel? Anyone have a video or photos to show what I should do?
I am doing this to ensure my brake lines and drive shaft are not limiting my travel.
Let's try an experiment.
Make a peace sign with you hand.
Now turn you hand so your fingers are parallel with the ground, inside fingers facing up.
Lay a pencil across the tips of your two extended fingers with an even amount of overhang on each side.
Your fingers represent the fully extended shock points when the axle is fully dropped by lifting the Jeep by it's body. The pencil represents your axle.
Now slowly raise you index finger upward and watch what happens to the opposite tip of the pencil.
This is because the shocks are not connected at the very end of the axle. Therefore, they act as a pivot point as you stuff the opposite wheel.
If you are checking for clearances you need to do both fully drooped and one drooped and one wheel stuffed as you have to deal with axle shift due to rotation and the affect that the track bar places on the axle, pulling the axle one direction and pushing it out in the other direction when drooped/stuffed.
I plan on disconnecting the swaybar links. Should I disconnect the shocks or anything else?
Does this sound like a good way of articulating the suspension or would you recommend another way?
I have (2) 6 ton jack stands capable of going to 23 3/4" of maximum lift
I have a 3 ton floor jack capable of going to 19 3/4"
Edit: My jeep is sitting on 35's with a OME lift using light springs and long travel shocks.
If you can find a ramp that is 20-30* you can pretty much check everything. go both sides and also up in reverse.
Dirtman is there a situation where offroad both front tires would be drooped enough to cause more clearance issues then having one fully stuffed and the other fully drooped. I can see the latter happening often. Also is there a situation where the track bar would be closer to the differential cover then having the drivers side fully stuffed and the passenger fully drooped like this? thanks.
