Chopped Flares
Old Oct 9, 2013 | 07:42 PM
SupraMatt95's Avatar
Default Chopped Flares
I'm sure there's 100 posts on this, but does anyone have a set or know someone that can chop the original flares or have a set they'd be willing to sell. I'm afraid to chop them on my own. I posted in the wanted section as well and I'm hoping to find someone that can help.
Thanks,
Matt
Old Oct 9, 2013 | 08:09 PM
mrmike's Avatar
It's really easy. Did mine this past Sunday with a Drexel and air cut off wheel. Just takes a long time to make straight lines. But the fender trim helps cover up some of the wiggly.
http://project-jk.com/jeep-jk-write-...ry-fender-chop
Old Oct 10, 2013 | 02:30 AM
kjeeper10's Avatar
Vet Army
I was afraid to cut mine. It's really not hard. Just follow the vids on youtube.
I actually marketed away from where I wanted to cut expecting mistakes. Well, that really wasn't the case. I ended up with more flare than I wanted, but actually really like the way they came out.
There is small waves which can be easily sanded. Still haven't finished and added the door trim.
Honestly .... I think it looks just fine and might just leave be.
ID:	503987   Click image for larger version
Old Oct 10, 2013 | 02:48 AM
kh202's Avatar
Man it's super easy to do, especially with plastic fenders. I've cut 3 sets. As said before, you can take as nasty as a hack you want, and then just smooth it out with sandpaper/ flapdisk. You can always just cut them wide and take more off and reshape them as you see fit. Here's two different ways I've had mine cut
ID:	503989Click image for larger version
ID:	503990Click image for larger version
ID:	503991Click image for larger version
Old Oct 10, 2013 | 03:15 AM
res6cueJK's Avatar
Where are you located? I know a guy that practically has multiple orgasms if someone lets them cut their fenders.
EGH - PTB
Old Oct 10, 2013 | 04:34 AM
JDub23's Avatar
Very true... super easy (more than I expected) I also left my chopped bumper w/o end caps (I noticed someone else on this thread), and did not put the door trim on at first... However, once I did - HUGE DIFFERENCE. I get stopped all the time and asked about them now. Take the time to finish them off by rounding the corners (use some card board as a template), a touch if super glue and $20 worth of door trim. Really finishes it off. I also picked up some LED corner lights - worth the $25.
~JDub
Sent from this Dang Thing
Old Oct 10, 2013 | 04:50 AM
familytime's Avatar
JK Forum Regional Rep
Super easy mod,just take your time
Old Oct 10, 2013 | 09:49 AM
Originally Posted by res6cueJK
Where are you located? I know a guy that practically has multiple orgasms if someone lets them cut their fenders. EGH - PTB
I'm at the PA/MD line
Old Oct 10, 2013 | 10:47 AM
nthinuf's Avatar
Another good step-by-step.
https://www.jk-forum.com/forums/jk-w...s-video-80145/
In case whoever you pay to do this easy task decides to remove the flares before cutting.
clipsandfasteners.com.
A20887 $8.92 box of 15
A11146 $2.97 box of 25
It's time to get familiar with 'your' jeep...
There are plenty of pics of the different cut styles to look at. Find the one you like, grab a roll of tape, and go mark them off to see what you think. As you stand there looking at them with the cut locations marked, you just might start to realize that it really isn't that big of a deal. ANY mistake you make can be pretty easily corrected by taking a tiny bit more off.
Old Oct 10, 2013 | 11:02 AM
Flexer07's Avatar
Here are mine. I was nervous at first but I think they turned out good
