Chromoly Axle Shafts Need Help
Old Mar 17, 2011 | 03:25 PM
robo_tn's Avatar
Default Chromoly Axle Shafts Need Help
i have a 2010 unlimited rubicon and need some chromoly axle shafts. what do you all have? and would you recommend them?
Old Mar 17, 2011 | 03:57 PM
Northridge4x4's Avatar
Sponsoring Vendor
Give us a call we have front and rear Chromoly's in stock
David
Old Mar 17, 2011 | 04:34 PM
YingYang's Avatar
Superior chromo's in the rear, picked up from Northridge 4x4. No issues.
Waiting now for Pro Rock Unlimited with RCV's, also from Northridge 4x4. Hurry up Dave!!!
Old Mar 17, 2011 | 08:49 PM
captjay's Avatar
David
Yes, Please give Dave a call, the customer service is outstanding and he will help you with what you need. I got my chromo shafts and many other parts from him
I would definitely recommend getting the chromo. For the front, it will have full circle clips which is a huge advantage over stock c-clips. For the rear, well, I have bent 2 stock D44 shafts at the flange, then finally replaced with chromo and no problems since.
Old Mar 18, 2011 | 08:03 AM
m(a)ce's Avatar
I got my RCVs (front) and Superiors (rear) through David. Solid so far.
also - right from Northridge they can press the bearings & set up your new rear shaft so you can keep your old ones as spares.
Old Mar 18, 2011 | 09:23 AM
Sponsoring Vendor
Correct if you order rear axles from us they come with new tone rings, backing plates and bearings!
