Clanking sound with sharp turns
Old Mar 5, 2013 | 04:51 PM
jeepjkgrrl's Avatar
Default Clanking sound with sharp turns
My jk is lifted 3.25" with 35" and has a front adj track bar and new steering stab. when i pull out of my driveway or into a parking spot i hear a clanking sound. not very lound and i get the death wobble once a month and at a speed of around 35-40 after hitting a bump.
Any Ideas?? or can you show me
My new steering stab bracket may be in the wrong position?
Old Mar 5, 2013 | 04:59 PM
ronjenx's Avatar
The only time I had a clanking noise in sharp turns, (which progressed to all the time), was when a front wheel u-joint lost a bearing.
The "X" was clanking around in the yoke.
Old Mar 5, 2013 | 05:13 PM
PANGMAN's Avatar
You may try tightening the bolts real good on the SS bracket. When I installed a new steering stabilizer bracket. It was clunking some when making slow sharp turns. Went away after I tightened it up.
Old Mar 5, 2013 | 06:26 PM
kjeeper10's Avatar
Vet Army
Check the track bar/bolts/bushings and mounting holes for wear. Fix immediately.
One episode of DW is bad for the front end and all components.
