Clear Coating Bed Liner
Old Aug 27, 2012 | 05:01 PM
TOTOZ's Avatar
Default Clear Coating Bed Liner
Hi guys,
I was thinking of spraying my stock JK rims using the black Rustoleum Bed Liner method. I was just wondering if they would need a clear coat over them? Not sure if bed liner is a similer process to spraying paint in which you would need to finally seal the paint with a clear?
Any help would be appreciated! thanks!
Old Aug 27, 2012 | 05:40 PM
SunnyD's Avatar
Nope, no clear coat necessary. There are a bunch of threads on this. Just make sure you scuff up your wheels with some sandpaper before you spray them.... Helps the liner stick.
Old Aug 27, 2012 | 08:33 PM
TOTOZ's Avatar
Ok thanks! cant wait to try it out. I just hope it really lasts. If you dont need a clear coat it must be durable then. does it dry a Matte or Satin finish?
Old Aug 29, 2012 | 05:53 PM
TOTOZ's Avatar
Default No good
well I went to buy some Duplicolor bedliner but to no avail! Apprently we dont have that stuff here down under. Im trying to find out what else I could use. Engine Enamel could be another option but i did find this stuff called "VHT- Hood, Bumper & Trim Paint".
I think this may be another name for bedliner but cant be sure. it has the same kind of material make up. Has anyone used this? I may give it a shot
