clearing 37s
Old Jun 25, 2013 | 07:42 AM
jksearles's Avatar
Default clearing 37s
Getting ready to go from 305s to 37 nitto trail gra. I have a 2011 jku with 3 inch zone suspension, I 3/4 coil spacers and body lift. Just want to make sure I will be ok on clearence/rubbing. I have stock fenderd and warn stubby rock krawler front bumper. Thanks
Old Jun 25, 2013 | 10:42 AM
jrod250's Avatar
Be prepared for everyone telling you that unless you have a d44 or d60 up front, that your axle will explode
Old Jun 25, 2013 | 10:48 AM
bob-o's Avatar
1 3/4" spacers or 3/4" spacers?
Old Jun 25, 2013 | 10:50 AM
kh202's Avatar
Helpful…
Best thing to do is put them on and go test them out flexing to see if you have to trim and bumpstop accordingly. You won't rub on the street provided you have the proper backspacing. And yes, I would highly recommend some reinforcement up front if you're running a stock axle. I would also bet that you'll want to cut the fenders after doing a flex test, depending how flexy your setup is
Old Jun 25, 2013 | 11:00 AM
D_engel's Avatar
you will need to trim your pinch seams in the rear to minimize rubbing. I run 37's and 2.5" lift and I was rubbing my pinch seam on the drive home from the tire shop. Just be prepared to hack up some sheet metal.
Old Jun 25, 2013 | 11:02 AM
kh202's Avatar
Good call, forgot that
Old Jun 25, 2013 | 11:12 AM
Yellowfin's Avatar
As was stated, as a preventative measure, I'd trim your rear pinch seam just in case. That way you can eliminate that being a point of contact. And then get on an RTI ramp or some place you can flex out your suspension and bump stop and trim accordingly. Sounds like you should probably have enough in the way of lift, but still need to do everything you can to prevent those tires getting into your body/flares, etc.
Old Jun 25, 2013 | 11:34 AM
jksearles's Avatar
Thanks everyone. For right now its primarily a daily driver so not really needing to flex much YET Ive been looking at the nitro sleeve to beefen up the front housing a little. For 100 bucks its a little added security. Anyone have any luck with the nitros?
Old Jun 25, 2013 | 11:42 AM
kh202's Avatar
I myself have the PureJeep axle backbone truss and gussets i got for $130 shipped. I'd throw gussets on there while you're at it for the price. Do you NEED them for street driving no, probably not. But a good ammount of strength added for a small price. My 2 cents.
Old Jun 25, 2013 | 11:59 AM
vman0715's Avatar
Did the same thing with basically the same setup. Definitely have to trim pinch seams. But even with trim I was rubbing with a full load of passengers. I went to 4" with no problems rubbing but now driveshaft angle can become issue
