Coast Drive Shaft Question
Originally Posted by Cold
Isnt that the part that rips off the stock drive shaft?
Be sure and check the u-bolts they sent you for installation. The ones provided for my install were to short and you could not get a full nut on the threads. The nuts were also plated soft steel rather than the hardened steel. I ended up going to an auto parts and buying new u-bolts made by Precision U-joints. The new u-bolts fitted as they should be and also had the hardened steel nuts.
put your shaft end on the ground (on an old piece of carpet or something) and give it a push down. Youll see that that is for corrosion protection as that area slides in and out to match individual driveline dimensions. You'll then see the grease on the blue coat.
BR
BR
