Coast DS Leak at Diff!!!!!!!
Old Aug 26, 2010 | 01:45 PM
scbesse's Avatar
Default Coast DS Leak at Diff!!!!!!!
This just started happening, i am thinking pinion nut backed off a bit????? DS is about 6months old. Any suggestions?Thanks
Old Aug 26, 2010 | 01:52 PM
Northridge4x4's Avatar
Sponsoring Vendor
See if you can pull up on the yoke. If the pinion nut is loose there will be play in the Yoke.
Has nothing to do with the Driveshaft . Get everyhting off and take a closer look to determine what happened.
David
Old Aug 27, 2010 | 04:13 AM
scbesse's Avatar
Yeah the yolk can wobble a bit when I pull on it.
Old Aug 27, 2010 | 04:16 AM
RyanBlack321's Avatar
I would pull it off and replace the nut with a new one and retorque it. I'd probably also service the diff. since you lost some fluid....
