Code problem?
Old Apr 24, 2012 | 07:47 AM
mook8651's Avatar
Default Code problem?
Had a code pop up C123C a dynamic something anyone know what this is?
Old Apr 24, 2012 | 07:51 AM
olram30's Avatar
https://www.jk-forum.com/forums/stoc...-p0405-115486/
Old Apr 24, 2012 | 08:04 AM
mook8651's Avatar
Doesn't really tell ya what to do to fix it... Just tell ya what it is I wipe the code out an I hasn't come back on since... I was only running with one sway bar link installed cause I bent the other wheeling.. Got new ones on now but just wondering what cause this to throw a code
Old Apr 24, 2012 | 08:07 AM
olram30's Avatar
it's about a 160 dollar part. but first check all the connections and if its on tight before you replace. not sure if there is a sure way to test it.
Old Apr 24, 2012 | 08:10 AM
olram30's Avatar
MODULE, SENSOR. Dynamics, Electronic Stability. Lateral Acceleration and YAW Rate. .
This fits your JEEP WRANGLER.
Stock Code 56029427AA
its a sensor for all above. best bet is to check the connections and make sure its on tight.
Old Apr 24, 2012 | 08:33 AM
mook8651's Avatar
Ok thanks again
