Code u0100 after using superchips
Old Feb 26, 2013 | 11:00 AM
BulldogMJP's Avatar
Default Code u0100 after using superchips
Does anyone else get this code after installing a superchips program. I was just playing with it and noticed the code after the install. Jeep drives fine so figure it's to do with the ecm being flashed. Code was not present prior to the install.:confused:
Old Feb 26, 2013 | 12:37 PM
Ryan0260's Avatar
I have never had a code after installing a tune. Maybe someone else who has experienced this will chime in. Or just get in touch with Ron at Superchips.
Old Feb 26, 2013 | 12:42 PM
SpicedCrusher's Avatar
That code is for a lost communications with ECM/PCM. Did you bump the cable or anything while it was flashing? Flash it back to stock, clear all present DTC's and re-flash your tune.
Old Feb 26, 2013 | 01:18 PM
BulldogMJP's Avatar
I'll flash back to stock tomorrow and then see if code comes back.
