Coil Lift Question
Im swapping out my Rubi shocks, coils and 2" spacers for a Rough Country 2.5" coil lift with shocks. The RC lift says it levels the Jeep (assuming it is stock) so the springs must be a little taller in the front. I have a RR front bumper, hoop, ends and skid adding up to about 130 lbs.
In the rear I have the RR XHD, Tire carrier and my new tire/wheel combo totaling about 280 lbs.
Should I add a spacer in the rear to level it out?? I dont mind a little rake, but I dont want any reverse rake.
However, that said, I'd add a spacer all the way around. I went with the 3.25" RC lift, and it's the same thing as you are looking at but with .75" spacers on top of their 2.5" springs. With the added weight, those .75" pucks should more than make up for anything you'll lose.
I wouldn't. As best as I remember, rear springs are able to handle more weight anyway. So, the extra weight in the rear shouldn't case a reverse rake.
I think im just going to put in the lift and see how it is. Plus its not like 100lbs added to the rear makes the front go up 1/4"...
Im still interested in other opinions though...
I would say put the spacer in! I put the terflex 2.5" on mine and it came with a rear spacer and spring guide. It didnt have a front one with the kit but it said it would be even with the rear. wrong.. shouldve put a front spacer in. my front is about 1/2" lower than the rear. just my .02
My question is if I need it in the rear. The RC coils themselves are supposed to level the jeep, but I have alot of extra weight in aftermarket parts (about double) in the rear...
I think u r going to be disapointed in the RC 2.5 coil lift. It doesnt give very much lift at all. I am running 2.5 coils with 1.75 front spacers and one inch rear spacers as well as coil correction wedges with 34s and my jeep doesnt sit that high imo.
I would get the 3.25 lift kit at a minimum. Actually I would either get the 4 inch kit or the Teraflex 2.5 coil lift kit. U may beed a new front DS with these two but since u have 4 door, your rear shuold be fine with either. Whatever u do dont use any cam bolts. The jeep will ride fine with 4 inch RC lift and not caster adj. I have stock control arms and ahve no complaints on how it drives.
Here is my jeep with above referenced setup:
Why are u changing what you have?
to the OP, you will want to add spacers. what size? wont know until the lift is on and you see how much height you lose. id guess 1/2"
Anyone else have a RC 2.5 lift with front and rear bumpers...
I think im not going to add the spacers and see how the rear is. Like I said, I just dont want any reverse rake, I just wasnt sure how the lift would handle the additional 285 lbs on the back and 130lbs on the front...
I had the 3.25 lift and was not happy with it, although the shocks aren't half bad. If they're still using the progessive coils get a different lift. I had RR bumpers front and rear and I pretty much lost any lift I gained with the RC 2.5 coils. I ended up getting OME coils to fix the sag and haven't looked back.
