coil over shocks and a lift
Old Jun 11, 2015 | 02:04 PM
rj'sjeep's Avatar
Default coil over shocks and a lift
So what would happen if i were to replace my bilsteins with some of the new coil over stocks from ome or fox ? Would the added springs on theses shocks make the rid much stiffer? Any thought? on a similar note if you were putting a new lift on your jeep and wanted to use these shocks would you have to go with a lighter spring or maybe no spring just the shock and spring? Are these newer shocks the same as older coil overs where the spring and shock is long ( I dunno the name of the them maybe eve or prison spider )
Old Jun 11, 2015 | 02:47 PM
JE8154's Avatar
Coil overs replace your shocks and springs. You aren't adding additional springs. That's about as far as I follow what you're trying to ask.
Old Jun 11, 2015 | 03:50 PM
D_engel's Avatar
Prison Spider doesnt make old, long shocks and springs. Sorry I couldn't help more.
Old Jun 12, 2015 | 05:57 AM
Maertz's Avatar
Based off your post id say you should avoid coilover or working on any suspension items on your jeep for that matter...
Old Jun 12, 2015 | 01:31 PM
rj'sjeep's Avatar
Default got that
I am not qualified to work on my suspension which is why I ask so many dumb ass questions.. no offense taken.
Old Jun 12, 2015 | 03:56 PM
Maertz's Avatar
But ill try and help explain stuff if i get your questions.
