Coil spacer question!!
Okay well today I put on the front 2in coil spacer on my jeep to level it out from the extra weight from my new bumper and winch and now the front sits a inch higher than the rear. Any ideas to what I should do?? Also will be installing a rear bumper and tire carrier with a 37in tire which will sag the rear even more.
Originally Posted by renpia
I put 1" in front and 2" in rear in my rig. Why 2" in yours? I would put 2" in back to level out.
Once everything is installed, just measure. Then buy the appropriate spacer length. My front sags 1.75 inches more than my rear, but I haven't got a new rear bumper yet.... so why should I bother?
You won't know until after everything is installed. I don't know why you would just add a 2" spacer without measuring. Chances are, once you add that rear and take the front spacer out, your Jeep will be level or sag only 1/2 inch.
