coil spacers
Old Mar 30, 2011 | 08:06 PM
Battlefrog's Avatar
Originally Posted by Battlefrog
Who's older.... Sit back and ride the school bus quietly youngling.....
Damn iPhone app. Quoted wrong post...
Old Mar 30, 2011 | 08:11 PM
Battlefrog's Avatar
Droid2Global > iPhone but, iPhone =
Droid.... Yea, Let me get a phone that has it's own star wars edition....
Old Mar 30, 2011 | 08:15 PM
Battlefrog's Avatar
Everybody makes a mistake, Apple just happened to make all of them at once and labeled it "iPhone"
How come you don't use the forum app on the droid...
Old Mar 30, 2011 | 08:20 PM
Battlefrog's Avatar
This is what happens when your stuck in the barracks with nothing to do. But, one more crack about my iPhone and I'll do a special relocate of your breathers when I come over for our custom snorkel project!
Old Mar 30, 2011 | 08:27 PM
Battlefrog's Avatar
Who had service when we were down at corolla? Oh yeah, my droid did. Who had maps when we were down there? Droid again! Who had a super sweet paper weight? iPhone for sure.
Coil spacers will work well for the OP.
Unfair assessment.... I had AT&T at the time....
Old Mar 31, 2011 | 03:40 AM
EzK's Avatar
EzK
The shocks should not limit travel. If you're using the shocks as travel limiters then the shocks won't last forever. There is a reason that professionals use travel limiting straps.
Just ab observation since it is the case with stock jeeps. I would guess that 95% of peoples down travel is limited by shocks. Do you use the straps? I don't see the point unless the shocks are WAY too short or you prerun it hard.
Old Mar 31, 2011 | 08:46 AM
Battlefrog's Avatar
On stock jeeps the downtravel is limited by the sway bar links. If you start picking up the body of the jeep the swy bar links extend all the way before the shock does. No, I don't run straps because my jeep is a daily driver. If I hit a 6" pothole then I deserve a bent rim.
My warning was to simply let people know that the stock shocks have a limited travel range and running them with a coil spacer lift without the shock extenders isn't the best idea. There has to be a reason the lift kits include shock extenders or longer shocks.
Damn you, go away!
Old Mar 31, 2011 | 08:57 AM
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
I was thinking about doing the same as the OP to my Sahara.
Dont want anything radical. Just something for a little edge.
Also thinking about Spidertrac wheel spacers
as I dont want the expense of getting new wheels/tires..
Old Mar 31, 2011 | 09:40 AM
Battlefrog's Avatar
Just found spider spacers for $125 brand new, never opened.
The coil lift will look good. I put rubi coils and shocks on with TF 2.5" BB and live it... Guess I kind of made my own coil lift...
Old Mar 31, 2011 | 03:39 PM
thitalian97's Avatar
ok so through all the b.s. on here i was able to piece a little bit together. new shocks are not necessary when it comes to coil spacers.
