coil spacers - JK
Old Aug 30, 2015 | 04:43 PM
Jimbo5741's Avatar
Default coil spacers - JK
What's thoughts on having 2" coil spacers on front and not the back to do away with it sitting lower in the front end. Bought the jeep with it having spacers all the way around but wanted opinions before I removed then. I am running 33s
Old Aug 30, 2015 | 04:51 PM
Albino Lizard's Avatar
When I put an AEV spacer lift on my jkur the 2" was stacked with the factory spacer in the front and the rear replacement spacer was about an inch and a quarter. You cant stack spacers on the rear. If you buy 2" spacers for the front and pull out the factory rubber it should level out.
