coilover recommendations???
Also, Since you can't afford The best coilover suspension kit, the evo lever system. The bolt on coil overs is the next best thing on the market.
Our bolt on coil over kit keeps the stock sway bar and exhaust system. While utilizing the factory shock location for optimal dampening and control. The king shocks are proprietary to EVO to achieve the most wheel travel possible.
yeah those look pretty legit, but I've been thumbing through threads and a lot of people seem to think EVO makes the best also that set is about $700 more than the EVO set. Anyone out there knowledgable enough to make a recommendation between the EVO bolt on and the rebel off road set?
I don't see why hydro bump stops would be needed unless your doing high speed desert racing. Just seams like a waste of $700 you could spend that on something better.
Originally Posted by chris@offroadevolution
Air bumps are an option. It depends on what your using the rig for if you need them or not.
