Coilovers benefit or not?
I have a 3" teraflex lift with 35s and I was thinking of coilovers. however I have no idea what they are or the benefit to them and if they are added on to your lift or not. being this is a forum and im still new at this educate me. I love learning. Thanks guys cheers
Coilovers are a shock and a spring in one unit. They are adjustable, rebuildable, and generally offer a better ride and better range of travel. They can be a pain in the butt to get set up right, you buy the coilovers, install them, do a bunch of math to figure out the correct springs, and then hope you were right and buy more springs because you probably werent (I did that 3 times). After you get them set up correctly they are night and day better than a coil spring and shock setup. Unless you are going really wild with your build, dont worry about them.
Also they are really expensive, a good set of front 2.0 coilovers is going to run you $1500-$2000 all said and done if you install them yourself.
Its all in how you take care of your jeep, if you don't wash it and run in the salt expect corrosion like any other shock. The greatest benefit of coil overs is the adjustability allowing you to dial them in for what you want. Properly maintained a coil over shock should last as long as your jeep.
I'm thinking that at $1500 - $2000 an end it is not going to happen all at once for most of us.
Due to the expense of coilovers:
Would it be 'better' to do the fronts first, or the backs?
What are the pros/cons of each?
Pricing will be determined on how you plan to mount them and if you can fab or not. Bolt on type will be more expensive cut to the mounts they use where if you can fab up the brackets and weld new mounts may save you $500+. Your choice of shocks will also make a difference as you can add several options like the res, compression adjusters, internal bypass, length, colors, and diameter of the shock. You can go to filthy motorsports and price out the shocks with options on their website so you can what you are going to pay there. I would recommend installing them on the front only simply because I don't like the stock mounting locations on the rear.
