Cold Air Intake
Hey Poordad, there are some pics of snorkel install and underhood in my album, check them out
http://s259.photobucket.com/albums/hh302/tkob1060/
Where in nj are you?
I got my cold air intatke, and had the first oil change done, so I felt alot of get up and go, but I assume it was mostly the engine finally breaking in.
I went back to stock from the Airade, I was just going the CAI until I could get a snorkel, but I don't like to avoid mud and water. I noticed, I don't have the growl that is awesome anymore, but going up hills in sixth gear, I drop speed a little faster, and It takes slightly longer to gain it back...
Does it make a difference? mine did. I get used to autos very quickly so I can tell little perceptions. Did it make a huge difference? no not really.
It makes a cool noise, like you have an engine under there, not mini-van guts, and makes throttle response, a little more responsive...
Still got the CAI taking up space in storage.
I have been thinking about getting one to. But lately I have read allot of people are getting h2o in their engines with these.....so now I am considering a snorkel, but wondering if that would be overkill for what I want. I am also concerned about snorkel in the snow....I am afraid heavy snow could block the intake.
I like it except for this.
What is the point of this thing here? It looks like the air comes in the top and it goes down through the filter and out the bottom?
Am I the only one who sees this as a horribly bad idea?
I doubt you will get enough water into your snorkel that it goes in this far, but if it ever did, instead of collecting in that black box, and you drain it out later, it goes straight into the intake of your engine? maybe not all at once, but drops here and there are sure to add up...
Ok, so I've been reading lots about CAIs. If I understand correctly, the positive is nominal increase in power (and a cool sound). The drawback is water in the intake (possibly). Would something like this be better?
So my other question, as I've been researching CAIs is this: Could you add a cone filter inside the stock airbox (I haven't looked at the airbox in depth, and it's 5:30am here, so I'm not going to ATM) and get some of the same benefits without the negatives of increased water risk?
I'm trying to figure out what I want to do here...
Does your Jeep feel like it has more HP when its cold out? Probably not, so why would you spend $250-$300 on a "cold air intake"? You may gain a couple of HP with a new filter element and a smooth intake tube, but it is hardly worth the $$$ in my opinion. If it is just the sound you are after, then go for it, but I wouldn't expect any noticeable HP gains. Dumping money into intakes and exhausts on a 3.8L jeep motor is like doing the same with a Ford focus or the like. It just isn't made to produce big HP, and benefits very little from these types of mods. I would spend my money elsewhere. Save up for new gears. This is just my opinion and I'm sure others will disagree.
