Cold-Air Intakes
Old Mar 17, 2009 | 08:35 AM
Vincent's Avatar
Default Cold-Air Intakes
Which CAI is preferred?
- Mopar
- XDI
- S&B
- K&N
- AEM
Also looking into Borla exhausts as well. Thanks!
Old Mar 17, 2009 | 08:37 AM
knyland's Avatar
I am running the Volant just because it has a snorkle option for me when I want or need one.
Old Mar 17, 2009 | 09:28 AM
Vincent's Avatar
Default cool
i'll check that one out man! thanx!
Old Mar 17, 2009 | 09:36 AM
JackMac4's Avatar
http://lmgtfy.com/?q=site%3Ajk-forum.com+which+cai
Old Mar 17, 2009 | 09:42 AM
Topher8668's Avatar
The stock rubber tubing that is on your existing intake is 3" i ordered a 3.5" K&N Airraid replacement filter and took out the old box. Strapped on the new filter over the existing tube with the screw straps. Then i used some firewall insulation to rap the rubber tube to keep the heat from the engine away. works great. I know its not esthetically pleasing but its cheap and super effective.
Old Mar 17, 2009 | 10:11 AM
joneszj's Avatar
The AEM Brute Force was my choice because it doesn't need oil. You clean it with the AEM kit which is basically soap and water. I couldnt be happier
Old Mar 17, 2009 | 10:12 AM
RevyJKU08's Avatar
- Mopar
- XDI
- S&B
- K&N
- AEM
I am looking at the AEM brute force for the filter....NO OIL Required.
I have had great luck with the Mopar and AFe CAI systems on my other vehicles. I have always added a pre-filter to stop the really fine Silty particles on Forest Service roads.
Old Mar 17, 2009 | 10:23 AM
greenamphibious's Avatar
OEM is my favorite. Comes with the Jeep and gives you the same amount of gains as all the ones you listed.... NONE
Old Mar 17, 2009 | 12:20 PM
Mr.ZAP's Avatar
AIRAID may be a pain to clean but it has a cold box which keeps mud, water and engine heat away from the filter. Definitely increases performance, and makes the engine scream when you throttle it
Old Mar 17, 2009 | 11:16 PM
aldaman's Avatar
- S&B
Been happy w/my S&B so far
