Which comes first
Old Apr 1, 2015 | 09:38 AM
GunDude's Avatar
Default Which comes first
Looking to upgrade steering a little more, with either Synergy drag link or tie rod. Starting to get a little play in steering. Want to stay ahead of it.
Old Apr 1, 2015 | 11:06 AM
mrmunsin's Avatar
Crawl under and hold the tie rod or drag link with both hands and have someone turn the steering wheel back and fourth you will be able to feel whatever is wrong, the ends will pop and move. I recommend replacing both at once just fixing one is just a band aid the other will wear out soon enough. When I did this found my drag link ends were shot my stabilizer blown and tie rod was bent replaced everything at once. Drives great now.
Old Apr 1, 2015 | 05:40 PM
JeepAngus's Avatar
What he said. Been through that with multiple Jeeps. Figure out what's wrong and then replace everything that needs replacing at one time. It all works together under your front end. Replace one thing but leave something else that's bad and your new thing will be trash before you know it.
