Compass
Old Mar 9, 2020 | 04:58 PM
BEEEAST's Avatar
Default Compass
Seems as though the compass in the BEEEAST is 180 degrees out of wack.
What's the fix for this?
80's AL
Old Mar 9, 2020 | 05:23 PM
ronjenx's Avatar
Most common cause is the compass has been removed for some reason, then installed 180° from the correct position.
A common cause for it to be off less than 180° is having something metallic or magnetic on top of the center panel.
Old Mar 9, 2020 | 05:27 PM
BEEEAST's Avatar
Huh.....ok. guess I will look into that.
thx
Old Mar 9, 2020 | 05:34 PM
nthinuf's Avatar
You could try a Manual Calibration and see if that does anything. The procedure is in the owners manual. (can be downloaded from the jeep website if you don't have one.)
