Compressor opinion
I searched and found that a few of you are running the cheap portable compressor from Harbor Freight. Is it this one?
http://www.harborfreight.com/cpi/cta...emnumber=93186
Will this inflate a 35 inch tire? I'm not sure what specs to look at to answer this.
well that says it will fill a "cars" flat tire in 3 minute not an suv or an oversized truck tire so i would prob double or triple that for a 35 inch tire not a bad price though at all !!
i have the Viair compressor with a tank i mounted where the exhaust used to be and put in a pressure gauge by the cupholders so i know how much PSI i have in the tank
I've got the step down from this one from harbor freight, it does okay if you are patient, I aired 4 tires from 10-12 psi to 32 in around 15 minutes. Stopped in Corolla at a gas station and finished up. The one you are asking about should do okay....
