Computer alignment, what to ask for?
Old Apr 23, 2012 | 08:33 AM
vulcan classic's Avatar
Default Computer alignment, what to ask for?
I recently installed a OME HD lift (springs/shocks) along with JKS adjustable front/rear track bars. Running 315/75-16's. I am installing a set of Rock Krawler adjustable front lower control arms this week and then will take it for alignment. What can I expect to have done at an alignment shop given the suspension setup I am running?
Will they adjust caster to factory spec or to a value I request given the lift height vs. stock (i.e. 5-5.5* vs. stock 4.2*)?
Toe-in?
Axle centering via the track bars? I already have it pretty close but is this included when its put on the rack, prior to setting toe-in?
Just trying to be informed to ask the right questions, thanks!
Old Apr 23, 2012 | 10:17 AM
jason0341's Avatar
I wouldn't even bring it in for an alignment. Set your own castor, toe, and axles. It takes a little time but it will also save you a few bucks. Plus you get to learn about your Jeep.
Old Apr 23, 2012 | 10:35 AM
Black-Shadow's Avatar
Default castors
I had to get my castors adjusted with only a 1.75" lift for the alignment machine to come out right
Old Apr 23, 2012 | 10:52 AM
sneck's Avatar
I think adjusting your own caster is certainly something you can do on your own, but getting it set perfectly will be no fun. And less fun is doing toe-in on your own, unless you have the proper tools. alignment is what, 60 bucks? Yeah, I think my time is worth more than that, I'd bring it in
Old Apr 23, 2012 | 02:14 PM
LOST's Avatar
Does it pull to one side?
I have an OME HD LT lift, JKS adj track bars and terraflex LCA's.
Tracks straight so I never got it aligned after we installed the lift.
Old Apr 23, 2012 | 05:25 PM
I set the LCA's to 23-1/8" per RK Instructions for 2.5-3.5" lift. I measured about +5* with iPhone angler finder measured at the bottom of axle C's. With the stock arms I was at about +3* after lift. I have about an 1/8" offset front and back on the axle centering but this should be done with wheels dead on straight to get it perfectly centered so I was thinking pro alignment would be best as well as setting toe-in
