Confused about spacers/adapters
Old May 30, 2014 | 03:58 PM
MLaborde's Avatar
Default Confused about spacers/adapters
I'm new to JK's. I've been a XJ & TJ owner since 1997 but just bought a JK last week.
I have a set of month-old 15x8 Pro Comp 97's (3.75" BS) that I really like & want to move from my TJ to my JK. I've done a LOT of reading but still keep coming back to the same questions. I'd like to get some help.
I know I need adapters to go from 5x4.5 to 5x5 bolt pattern. From what I've read, I may or may not need spacers. The adapters I've seen are all 1.5" adapters so they are also 1.5" spacers.
So... Question 1 is: How could someone say that they can use 15" wheels with no spacers if all adapters are also at least 1.5" spacers?
Question 2: If I use my Pro Comp 97's and 33x12.5x15 DuraTracs, will I need to recalibrate the speedo or make any other mods to keep everything reading right? If so... recommendations?
Thanks!
Last edited by MLaborde; May 30, 2014 at 04:05 PM. Reason: I type like old people f...
Old May 30, 2014 | 04:24 PM
tribulation138's Avatar
Thanks!
Yes your speedo will be off. Bigger the tire the more error. I have 33s and I noticed right away. You can get the jeep procal to fix speedo error
They make all different size spacers. I had 3 inch spacers on my stock 29 inch jk tires. Then I bought some used rims that had a 5.5 lug pattern so I had to buy adapters that were 1.5 inch 5.5 to 5.0 adapters. The tires i have are 33x12.50x15 stuck out wicked bad. I got rid of those rims and bought brand new 15 inch rims with right lug pattern and a 4.00inch back space. Cleaner look and dont stick out as far maybe 2.5 inches from fenders.
Old May 30, 2014 | 04:26 PM
nthinuf's Avatar
1. They buy the correct 15" wheels with a 5x5 pattern, so they don't need adapters?
2. If you don't want your speedo/odo to be correct, then don't worry about recalibrating for the taller tires.
Old May 31, 2014 | 02:28 AM
OH9JK's Avatar
JK-Forum Ambassador
This plus I would add that if you add spacers/adapters to your wheels that already have a 3.75" backspace you will end up with a 2.25" back spaced wheel....this will push your tires out pretty far!
Old May 31, 2014 | 08:47 AM
MLaborde's Avatar
Thanks, everyone, I think I have decided to just buy new alloy 15" rims and be done.
Old May 31, 2014 | 09:58 PM
ROGUE JK X's Avatar
If I'm not mistaken, TJ's have a 5 on 5.5 and JK's have a 5 on 5 so I'm not sure if they'd fit.
I have 15" rums with no spacers. on a JK if you have 4.25"-4.5" back spacing you'll be able to have 12.5" wide tires
Speedometer will be slightly off. when i went to 35's its about 5 off in the 30 range.
Old May 31, 2014 | 10:32 PM
nthinuf's Avatar
4.5 or 5.5 doesn't matter - won't fit a JK without adapters.
15" rims have issues with clearing the brakes, so he wants a backspace of 4" or less (depending on the specific rim). 3.75" or less would be better.
Old Jun 2, 2014 | 09:10 AM
MLaborde's Avatar
To avoid all chances of confusion and problems I purchased 15" Level 8 Trackers (alloy) to go with my new 33x12.5x15 Duratracs.
Got them from DTD based in his informative thread here and a good price.
They are supposed to fit without spacers without problem.
