Confused on Lift options
Old Jan 4, 2013 | 07:23 AM
swoosh53's Avatar
Default Confused on Lift options
I am a new jeep owner (2 years), I have a 2008 Jk unlimited Sahara edition. I am a light off-roader but mainly use my jeep on the paved streets. I would like to lift my jeep in order to put some larger tires on it. I am simply going for the look. Here is my question;
Should I just do a body lift or a full suspension lift?
Does anyone know the difference between these. What are the adapters for?
JK Wrangler 2.5" Performance Budget Boost - No Shocks
SKU: 1355200
$272.99
JK Wrangler 2.5" Performance Budget Boost w/adapters - No Shocks
SKU: 1355210
$357.99
Old Jan 4, 2013 | 07:24 AM
NoVA_JeepBoy's Avatar
If you aren't doing much offroading, you can do a budget boost, like 2.5 and then get up to 35" or 37" with flat fenders.
Old Jan 4, 2013 | 07:28 AM
tiltz's Avatar
If you you mostly want the tires for looks you should consider getting a budget boost (which is just coil spacers and a couple other odds and ends). The modification is cheap and easy to install.
A body lift will be slightly more involved and doesn't have much of a benefit. Do some searches and you will find quite a bit of information
Old Jan 4, 2013 | 07:40 AM
gunbo75's Avatar
Welcome to The forum. X 2 on a budget boost or a teraflex leveling kit.
Old Jan 4, 2013 | 07:53 AM
tiltz's Avatar
double post
Old Jan 4, 2013 | 08:00 AM
TeraFlex's Avatar
Sponsoring Manufacturer
How big of tires do you want to run?
Old Jan 4, 2013 | 08:31 AM
Rock Krawler Suspension's Avatar
Former Vendor
Tire size is a great place to start when choosing a lift!
RK
Old Jan 4, 2013 | 08:33 AM
swoosh53's Avatar
Default Thanks!
Thank you for the information!
Old Jan 4, 2013 | 08:38 AM
swoosh53's Avatar
Can you tell me what the difference is between these 2? What are the adapters for?
SKU: 1355200
$272.99
SKU: 1355210
$357.99
Old Jan 4, 2013 | 08:45 AM
TeraFlex's Avatar
SKU: 1355200
$272.99
SKU: 1355210
$357.99
The adapters allow you to reuse the stock shocks. The #1355200 is for customers that are using another brand of shock. You will need shocks with this kit.
