CONFUSED.... someone clarify!!!!!
Old Mar 17, 2011 | 07:42 PM
JKU's Avatar
JKU
Default CONFUSED.... someone clarify!!!!!
Ok, so i just got back home from the dealer (I HATE DEALERS!!!) and in their showroom they had a brand new JK w 295/70/18 Nitto trail grapplers no lift (i asked), they looked huge on it so i went on Nittos site and looked the specs on the tire: the height is 34.57....I have 295/70/17s and they are only 33.54 according to the site... WTF?! is this right??? can it be right? AND according to the site 35/12.50/ 17 is 34.84 tall.... so if the dealer installed 34.57 in tires on a stock JK w no lift can i install 34.84 tires on my JK with a 1.5 lift???? Could the specs on the Nitto site be wrong???
Old Mar 17, 2011 | 07:44 PM
JKU's Avatar
JKU
the 34.84 being 35/12.50/17s
Old Mar 17, 2011 | 07:47 PM
speed2005's Avatar
Take any pics? What kind of wheels were they on?
Old Mar 17, 2011 | 07:49 PM
highoctane's Avatar
A 295/70/18 should be 1" taller than a 295/70/17. The first number is the tread width in mm, so 295mm. The second number is the height of the sidewall. Sidewall height on a metric tire size is a percentage of tread width. So both the tires mention have a sidewall height of 70% 295mm, so right around 206.5mm sidewall height. The 17 is going to be 1" smaller due to the wheel size being 1" smaller.
jmat1980's Avatar
Different brands will measure differently even if the size is the same. The specs on the websites are un mounted. There are alot of variables to consider like rim width weight on the JK and tire pressure. If your tires measure 33.54 on the Jeep, off the Jeep they are prob like 34.5 or so. The tires on the dealer JK were not 34.57 mounted, they were prob like 33.75 or something. Also I would bet money that the dealer had the tire pressure at like 50
Old Mar 17, 2011 | 07:52 PM
JKU's Avatar
JKU
Oh, i forgot to mention i also have Nitto trail grapplers on my JK.
u-joint's Avatar
What
You don't run yours at 50 PSI
Old Mar 18, 2011 | 03:23 AM
GentlemanFarmer's Avatar
x2 295/70/18 should be taller
Old Mar 18, 2011 | 03:35 AM
aldaman's Avatar
x2 to the posts above....
295/70/17=33.25"
295/70/18=34.25"
Old Mar 18, 2011 | 03:55 AM
rexicon's Avatar
They may have 35's on it with no lift but it will rub the fenders off road and probably pop them right off.
